Derate factor
- coolmanhalo
28 Nov 2013 01:29 #1997
by coolmanhalo
Derate factor was created by coolmanhalo
The derate factor by default is 0.77
The website seems unclear if the number is for no tracking, single axis, or 2 axis.
Could you suggest the appropriate multipliers
thanks
thanks
02 Dec 2013 16:51 #1998
Replied by Paul Gilman on topic Derate factor
I assume you are asking about the default value of the DC to AC derate factor for SAM's PVWatts model.
PVWatts calculates the incident radiation for each hour of the year based on the array's orientation and the sun's position in each hour. The derate factor is independent of the tracking option.
- ENRES2018
30 Jan 2014 03:05 #1999
by ENRES2018
Replied by ENRES2018 on topic Derate factor
I want to oversize the solar PV array comparatively to Inverter power, how to configure the derate factor greater than 1?
03 Feb 2014 14:57 #2000
The PVWatts model assumes that the inverter AC capacity is equal to the array DC capacity, so it is inherently oversized by the inverter's conversion efficiency.
The Flat Plate PV model may be a better option for this kind of analysis. That model has a DC-to-AC ratio input (on the Array page).
