Collector azimuth angle input field ghosted in CSP Linear Frensel
- williampaulbell
10 Nov 2013 16:30 #1920
by williampaulbell
Collector azimuth angle input field ghosted in CSP Linear Frensel was created by williampaulbell
Hello Paul
Could you let me know if there is a way to alter the "Collector azimuth angle" field in the CSP Linear Fresnel technology. The field is currently ghosted.
Regards
William Bell
Regards
William Bell
14 Nov 2013 10:03 #1921
Replied by Paul Gilman on topic Collector azimuth angle input field ghosted in CSP Linear Frensel
Dear William,
The linear Fresnel model's collector azimuth angle input variable is only active with one of the incident angle methods of characterizing the collector optical characteristics on the Collector and Receiver page. When the option on that page is "Solar position table," the azimuth angle variable on the Solar Field page is inactive (or ghosted, as you note).
On a related note, it turns out that there is a bug that causes the variable to be inactive with the "Collector incidence angle table option" when it should be active. We will fix that in an update that we plan to release soon. (Your question helped us find the bug, so thanks!)
Here is the correct behavior:
Optical Characterization Method
Azimuth Angle Status
Inactive
Active
Incidence angle modifiers
Active
Inactive
Active
Active
