Flat Plate PV model - user entered hourly data for electric load
- judsannu
02 Nov 2013 13:13 #1899
by judsannu
Flat Plate PV model - user entered hourly data for electric load was created by judsannu
Need help with entering 15 min data.
I have created a single column with 8760 x 4 rows of data in excel spread sheet.
In the Edit data option, I changed the time step to 15.
copied and pasted the column containing 8760 x 4 rows and Ok
For some reason, I am not getting the total kWh from the load data
Am I doing something wrong?
Thanks.
Joe Judge
Thanks.
Joe Judge
05 Nov 2013 11:36 #1900
Replied by Paul Gilman on topic Flat Plate PV model - user entered hourly data for electric load
Dear Joe,
Please open the file with a text editor and make sure there are no commas at the end of rows.
Also, be sure that your data starts in Row 2 (Row 1 is for header information). The file should have a total of 8760 x 4 + 1 rows.
If your file still does not work, please attach a copy of it to your original post, and I will try to help troubleshoot it.
- judsannu
05 Nov 2013 23:06 #1901
by judsannu
Replied by judsannu on topic Flat Plate PV model - user entered hourly data for electric load
Thanks Paul.
While reviewing the manual:
Under the Time Step and Convention - For sub-hourly data, SAM requires a column of 8,760 รท Number of Times Steps per Hour rows, with kilowatt values representing the average electric power over the period of a single time step.
I noticed that for the sub-hourly data, the code is dividing 8760 hours by the number of steps and not multiply .
Am I missing something here?
Thanks for your help.
Joe
Joe
06 Nov 2013 10:01 #1902
Hi Joe,
That is a typo. The electric load data file should have 1 header row + 8760 x number of time steps per hour data rows. The header row is is the first row. An hourly data file would have a total of 8761 rows. A 15-minute data file would have 1 + 8760 x 4 = 35,041 rows.
The best way to check the file format is to export a test file from the Edit Data window, which you open from the Electric Load page by clicking User entered hourly data and then Edit Data.
I will fix the description in Help.
