epw files
- mohamedsaid
25 Oct 2013 17:02 #1890
by mohamedsaid
epw files was created by mohamedsaid
I download epw weather files for Egypt cities but an error message appears when selecting the file in the program. Please tell me how to get the weather file or what is the problem? the link of the site that from i download the epw files is:
apps1.eere.energy.gov/buildings/energyplus/cfm/weather_data3.cfm/region=1_africa_wmo_region_1/country=EGY/cname=Egypt
01 Nov 2013 12:16 #1891
Replied by Paul Gilman on topic epw files
Dear Mohamed Said,
Can you tell me which files you are having trouble with? I tested the Cairo.Intl.Airport_ETMY, Aswan.624140_ETMY, and Aswan.624140_IWEC files, and they worked fine with the physical trough model.
- IsmailJamal
16 Mar 2015 01:03 #1892
by IsmailJamal
Replied by IsmailJamal on topic epw files
when i start simulation this message appears
failed to read local weather file: C:/SAM/EGY_Cairo.Intl.Airport.623660_ETMY.epw error reading data column type specifier in col 1 of 34: 'typical/extreme periods' len: 23
Simulation windpower failed.
16 Mar 2015 10:27 #1893
SAM's wind power model requires a weather file in the SRW format. It does not work with EPW or other file formats designed for solar resource data.
For a description of the SRW format, please see the "Weather File Formats" topic under "Weather Data" in SAM's help system.
