New Model
23 Sep 2013 14:51 #1819
New Model was created by Paul Gilman
Hello, I am interested in using this program to analyze our product, which is a PV inverter. Would you please let me know how I can enter a new product that is not available in the current set of choices? Thank you.
As of SAM 2013.9.20, you can use the "Inverter Datasheet" option on the Inverter page to model an inverter that is not included in the SAM inveter library.
To use that option, you will need data from the inverter manufacturer's data sheet.
- mfurukawa
04 Oct 2013 11:09 #1820
by mfurukawa
Replied by mfurukawa on topic New Model
If we had data similar to the CEC efficiency curve, is there a way to input multiple curves at different voltages in a single program by using the part load curve option?
Thank you.
Thank you.
07 Oct 2013 11:08 #1821
Replied by Paul Gilman on topic New Model
No. The "Inverter Part Load Curve" option allows you to enter a table of values for inverter efficiency for different power levels at the nominal DC voltage, but not at different voltages.
