Error Message on Wind Project
- Tsitsi Musasike
26 Mar 2026 10:16 #14515
by Tsitsi Musasike
Error Message on Wind Project was created by Tsitsi Musasike
Good day
I am trying to run a simulation on the SAM for a hybrid solar, wind an BESS project in Namaqualand, South Africa. I keep getting the error below:
Could not check hub height compared with resource height. This may indicate problem with your weather file.
When I changed the hub height to a Vestas 164 8MW, I get the error message below:
Complete fail hybrid.
Simulation complete fail.
May I kindly request that you review our data (attached) and advise how to fix the problem?
I have attached the data file.
Thank you so much.
Warm regards
Prof. Tsitsi Musasike
Thank you so much.
Warm regards
30 Mar 2026 10:17 #14518
Replied by Paul Gilman on topic Error Message on Wind Project
Hi Tsitsi,
That message indicates there may be a problem with the format of your wind resource file. Please see the "SAM CSV Format for Wind" topic in help for a description of the format.
samrepo.nlr.gov/help/weather_format_csv_wind.html
If you continue to see the message and would like me to help troubleshoot, please attach a copy of the wind file you are using for this simulation.
- Tsitsi Musasike
30 Mar 2026 19:53 #14519
by Tsitsi Musasike
Replied by Tsitsi Musasike on topic Error Message on Wind Project
Dear Paul
Thank you very much. Please find attached the file for review.
Warm regards
Tsitsi
Warm regards
Tsitsi
31 Mar 2026 09:25 #14520
Hi Tsitsi,
I was able to run a simulation for both cases in your "TEST 4.sam" file with the "TRY 1.csv" wind resource file, so the wind resource file format appears to be correct.
I tested this in SAM 2025.4.16 in Windows. Are you using a different version of SAM or a different operating system?
Also, I did notice a column in the "TRY 1.csv" wind resource file with the heading "air temperature at 10m-60m (C)". This does not follow the format requirement because it includes two heights above the ground. I would either remove that column from the file because there is already a column for air temperature at 60 meters, or change the height from "10m-60m" to "10m".
- Tsitsi Musasike
02 Apr 2026 09:20 #14526
by Tsitsi Musasike
Hi Paul
The student has adjusted the column, but now can't run the simulation despite the file being practically the same. I attached the file. It says the data records are not enough, however I am certain that there are 8760 rows (not counting the headers!). Any ideas on how to proceed?
Thank you so much.
Warm regards
Thank you so much.
Warm regards
02 Apr 2026 13:07 #14527
Hi Tsitsi,
I don't think there is a problem with the weather file itself in this case. There seems to be a problem with SAM's ability to open or read the file. A couple of things to try are putting the weather file in a different folder, or seeing if it will work on a different computer.
