Shading calculator: Google API key outdated?
- Markus Rinio
18 Mar 2026 09:09 #14510
by Markus Rinio
Shading calculator: Google API key outdated? was created by Markus Rinio
When trying to build a 3D-scene for shading calculation based on google maps, I get "Time Zone API Error!", a lot of follow up errors, and no Google map. My AI-chat says, this has to do with an outdated google API key, which is hardcoded in SAM.
How can this be solved?
(I am using sam-windows-2025-4-16-r1, downloaded last week.)
18 Mar 2026 11:11 #14511
Replied by Paul Gilman on topic Shading calculator: Google API key outdated?
Hi Markus,
The static map download feature for SAM's 3D shade calculator does not work as of SAM 2025.4.16. The workaround is to create a map image outside of SAM and click Load image on the shade calculator's Location tab to import it and then click Underlay this map in the scene to set it as the scene's underlayed map.
Your chatbot was close, but not exactly correct. SAM relies on a Microsoft Azure API for this service, not a Google API. And, the API key is not outdated, it doesn't exist.
For more details, you can see the SAM release notes at natlabrockies.github.io/SAM/doc/releasenotes.html , and this GitHub pull request: github.com/NatLabRockies/SAM/pull/2093 .
