Wind Farm Simulation Produces Almost Zero Output
- Aliiii
13 Jan 2026 06:20 #14450
by Aliiii
Wind Farm Simulation Produces Almost Zero Output was created by Aliiii
Hello,I'm currently working on a wind farm simulation in SAM using the Wind Power module with real location data from NSRDB (converted to
format)
Problem:
Even though the resource file is valid and accepted by SAM, the simulation result shows an Annual AC energy of only ~1 MWh, and a capacity factor of 0.0%, which is not realistic for a 301.3 MW wind farm using Siemens SWT-2.3MW-101m turbines. Here’s what I’ve checked :
.srw
Problem:
- The
file which is valid and accepted by SAMCode:.srw
- The turbine selection is correct from the SAM library.
- The layout contains 131 turbines properly located and imported via CSV
Attachements: -
file structureCode:.srw
- Wind turbine selection and specs (Siemens SWT-2.3MW-101m)
- Turbine layout imported (131 turbines)
- Simulation output showing 0% capacity factor and monthly AC output chart
- Sample hourly data showing non-zero wind speeds but no generation
Can someone help me understand where i went wrong or why SAM fails to generate close to realistic power output from this setup?
14 Jan 2026 10:05 #14451
Replied by Paul Gilman on topic Wind Farm Simulation Produces Almost Zero Output
Hi Aliii,
The atmospheric pressure data in your file appears to be in the wrong units: The values are on the order of 1000, but I would expect them to be on the order of 1.
Please try replacing the pressure data with values divided by 1000.
