Questions on HTF Temperatures & ORC Template Table in CSP Tower Molten Salt
- Samin
24 Jul 2025 05:01 #14174
by Samin
Questions on HTF Temperatures & ORC Template Table in CSP Tower Molten Salt was created by Samin
Hello SAM community,I’m setting up a CSP molten-salt power tower with a user-defined ORC cycle (R600) in SAM 2025.4.16 and have a few questions:1. System Design → HTF hot/cold temperature
- In the System Design tab, should the “HTF hot temperature” and “HTF cold temperature” fields be set to the maximum and minimum operating temperatures of the molten‐salt loop (e.g. 565 °C / 290 °C for a solar salt)?
- Or should they instead reflect the temperatures of my ORC working fluid?
- Under Power Cycle → Create a template table…, the independent‐variable axes ask for Low HTF temperature, Design HTF temperature, and High HTF temperature.
- Are these values referencing the molten salt inlet temperature to the ORC heat exchanger, or the internal working‐fluid (R600) evaporation/condensation temperatures?
- Is it acceptable (or recommended) to generate the 180×5 independent‐variable “template table” for the ORC via a MATLAB script using the CoolProp library (e.g. looping over HTF T, normalized ṁ, ambient T and exporting Q/P values)?
- Has anyone successfully automated their Power-Cycle table this way?
24 Jul 2025 11:12 #14175
Replied by Paul Gilman on topic Questions on HTF Temperatures & ORC Template Table in CSP Tower Molten Salt
Hi Samin,
For questions 1 and 2, those temperatures refer to system operating temperatures rather than fluid properties.
For question 3, I'll defer to others. I am not familiar with the CoolProp library.
- Samen
28 Jul 2025 04:27 #14184
by Samen
Replied by Samen on topic Questions on HTF Temperatures & ORC Template Table in CSP Tower Molten Salt
Can you help me with any paper or related research work? I am working on a CSP power tower molten salt technology using Organic Rankine Cycle as working fluid.
28 Jul 2025 09:11 #14185
Hi Samen,
See the CSP Publications page on the SAM website for a list of publications about SAM's concentrating solar power and industria process heat models: sam.nlr.gov/concentrating-solar-power/csp-publications.html
