Efficiency Deratings based on Measured Cell Temperatures (instead of a-b-dT model)
- PhilippS
05 May 2013 02:06 #1589
by PhilippS
Efficiency Deratings based on Measured Cell Temperatures (instead of a-b-dT model) was created by PhilippS
I am trying to model a PV module with unusual thermal properties in SAM. Since it doesn't dissipate heat to ambient straightforwardly, I would like to input measured data for cell temperature T(t) over the year and let SAM apply the correct efficiency deratings for these temperatures.
What would be a good path to simulate this effect?
I'd like to do it well, as this is important for the value proposition of my scenario.
Best,
PhilippS
Best,
PhilippS
06 May 2013 09:07 #1590
Replied by Paul Gilman on topic Efficiency Deratings based on Measured Cell Temperatures (instead of a-b-dT model)
Dear PhilppS,
As you know, SAM's different PV module models offer different algorithms for estimating the cell temperature based on the ambient temperature, wind speed, and incident radiation.
The temperature correction algorithm for the Sandia module model uses the coefficients a, b, and dT. The algorithm is described in general terms in the Module topic of SAM's Help system, and in more detail in King et al (2008), which you can find on the Performance Models page of the SAM website.
Unfortunately, SAM does not offer an option to provide the cell temperature as an input.
