TES Packed bed in parabolic trough CSP
- Guillermo Manuel García Díaz
19 May 2025 03:55 #14049
by Guillermo Manuel García Díaz
TES Packed bed in parabolic trough CSP was created by Guillermo Manuel García Díaz
Hi,I'm working with the packed bed TES model for a parabolic trough CSP system in SAM, and I noticed that the "TES discharge thermal power (MWt)" values are much higher than the "Estimate max TES discharge thermal power (MWt)" (see attached screenshot).Shouldn't the estimated value represent the upper limit? Is this expected in the packed bed model, or could it indicate a problem in the configuration?Thanks in advance!
- Ty Neises
19 May 2025 10:14 #14051
by Ty Neises
Replied by Ty Neises on topic TES Packed bed in parabolic trough CSP
I agree that the results are unexpected. Can you please share the file that generated these results?
Ty
NREL
Ty
NREL
20 May 2025 15:39 #14052
Replied by Guillermo Manuel García Díaz on topic TES Packed bed in parabolic trough CSP
Hi Ty,Thank you for your response.
I’m attaching the .sam file that generated those results
- Ty Neises
21 May 2025 14:30 #14058
by Ty Neises
The 2024 SAM release contained a unit error in the outputs that caused the issue you showed. The 2025 release fixes the problem.
