Inverter Setup Error
- Alireza Moradmand
23 Apr 2025 00:53 #14000
by Alireza Moradmand
Inverter Setup Error was created by Alireza Moradmand
I'm a mechanical engineering student. As a part of my bachelors project I need to model a PV powerplant with a 125kW inverter. But unfortunately SAM is unable to model an inverter with 9 MPPT inputs. I have included the inverter datasheet. How should I model this inverter? Should I model it with 1 MPPT inputs and scale it?
My selected inverter is Solis-125K-EHV-5G-US-PLUS
Thank you very much
Thank you very much
23 Apr 2025 14:23 #14001
Replied by Paul Gilman on topic Inverter Setup Error
Hi Alireza,
If all of the modules in the array have the same orientation, tracking, and shading, you can model the inverter as a single MPPT input.
It is not possible to model a system with 9 subarrays that each have different orientation, tracking, etc. because SAM is limited to a system with up to four subarrays.
This is an item on our wish list, but we do not have current plans or resources to allow more than four subarrays: github.com/NREL/SAM/issues/1700 .
Paul
Paul
