Importing SAM configuration: JSON to python
- Ana
19 Mar 2025 17:53 #13965
by Ana
Importing SAM configuration: JSON to python was created by Ana
Hi! After attending the webinar today, I'm trying to configure a residential solar + storage setup, now aided by parameters configured in the SAM UI, exported as JSON, and imported into my python notebook for use.
I am importing them like this, as specified on the SAM defaults documentation :
Running this code I get an error:
It appears to fail on setting:
after setting all previous parameters as expected.
Is there an issue with the parameter import / setup, or is there a workaround I could pursue?
Relatedly, how could I access details regarding the battery? Even though I have configured it in the SAM UI, it does not appear to have an associated JSON configuration that is exported.
Using SAM:
Version 2024.12.12, 64 bit
SSC Version 298: OS X 64 bit GNU/C++ Dec 11 2024 22:29:29
wxWidgets 3.2.6 on macOS Sonoma Version 14.5 (Build 23F79)
Internet connection method: default
Display: 1512 x 982, magnification 1x
Attached: JSON files generated by SAM, not including utitled.json, also sccapi.h and scc.dylib. Screenshot of battery configuration in UI.
import json
import PySAM.Pvsamv1 as PV # Adjusted from Pvwattsv8 since I noticed that this was not one of the exported JSON files
import PySAM.Grid as Grid
import PySAM.Utilityrate5 as UtilityRate
import PySAM.Cashloan as Cashloan
pv = PV.new()
grid = Grid.from_existing(pv)
ur = UtilityRate.from_existing(pv)
cl = Cashloan.from_existing(pv)
dir = "SAM_configuration/"
file_names = ["untitled_pvsamv1"] # "untitled_grid", "untitled_utilityrate5", "untitled_cashloan",
modules = [pv] # grid, ur, cl
for f, m in zip(file_names, modules):
with open(dir + f + ".json", 'r') as file:
data = json.load(file)
print(file)
for k, v in data.items():
print(k)
print(v)
if k != "number_inputs":
m.value(k, v)
AttributeError Traceback (most recent call last)
Cell In[29], line 14
12 print(v)
13 if k != "number_inputs":
---> 14 m.value(k, v)
AttributeError: "value" error, could not find attribute by that name
batt_adjust_constant 0
Using SAM:
20 Mar 2025 17:53 #13966
Replied by Paul Gilman on topic Importing SAM configuration: JSON to python
Hi Ana,
There seems to be a problem with the battery_adjust variables. As a workaround, please try deleting the following variables from the untitled_pvsamv1.json file:
batt_adjust_en_timeindex
batt_adjust_en_periods
batt_adjust_timeindex
batt_adjust_periods
After deleting those files, you'll need to do the following to get a test pvsamv1 simulation to run:
1. Set the value of 'load' in the untitled_pvsamv1.json file to an array with the same length as 'crit_load'.
2. Set the value of 'solar_resource_file' to a valid path to a solar resource CSV file.
Then, you should be able to run the PV model and show results with:
pv.execute()
print(pv.value('annual_ac_gross'))
The battery inputs are in the untitled_pvsamv1.json file. Many of them have a "batt_" prefix. The are listed in the PySAM documentation for the Pvsamv1 moudule here:
nrel-pysam.readthedocs.io/en/main/modules/Pvsamv1.html#batterycell-group
nrel-pysam.readthedocs.io/en/main/modules/Pvsamv1.html#batterydispatch-group
By the way, those ssc_api.h and ssc.dylib files are not required to run PySAM.
batt_adjust_periods
pv.execute()
