SAM only begins to show output at wind speeds above 14m/s
- WillStewart
27 Mar 2024 12:17 - 28 Mar 2024 13:36 #13027
by WillStewart
SAM only begins to show output at wind speeds above 14m/s was created by WillStewart
(resending as first submittal threw an error message)
SAM 5.1.0 (model attached)
Data: From NREL Wind Toolkit South Atlantic Offshore, site 244529 (file attached)
Issue: SAM only begins to show output at wind speeds above 14m/s, though this turbine starts outputing at 3m/s, with max output at 10 m/s
Turbines: 165 of 2020 ATB NREL Reference 15MW
Also the CF is 0.4%, and monthly and annual outputs are two orders of magnitude below expected output.
Last edit: 28 Mar 2024 13:36 by Paul Gilman. Reason: Attach wind resource file from duplicate post
28 Mar 2024 14:11 #13033
Replied by Paul Gilman on topic SAM only begins to show output at wind speeds above 14m/s
Hi Will,
Thank you for the detailed post with supporting files. We are investigating and I will get back to you as soon as I know more about what is causing this.
- WillStewart
08 Apr 2024 05:53 #13068
by WillStewart
Replied by WillStewart on topic SAM only begins to show output at wind speeds above 14m/s
Thank you, Paul, I look forward to your reply
09 Apr 2024 09:42 - 11 Apr 2024 11:58 #13072
Hi Will,
I think the air pressure data in your file is off by a factor of 100. The values are in the range of 995 Pa instead of 99,500 Pa. I tried modifying your weather file by replacing the column of air pressure with values in the correct range and got simulation results that made more sense.
Note that SAM ignores columns of data in the weather file that it doesn't recognize, so you can keep the old pressure data in your file as long as the column heading does not contain "pres".
See github.com/NREL/SAM/issues/1756 .
Last edit: 11 Apr 2024 11:58 by Paul Gilman.
