Generic-Battery System data table
- dawon
25 Mar 2024 23:57 #13023
by dawon
Generic-Battery System data table was created by dawon
Hi, thanks for answering my questions so quickly each time.
I have an additional question here
I'm using the generic-battery project.I have set both the power plant and battery options the same and only the BTM storage option is different and I want to compare the results. I compared the results of "electricity load" with 3 different options "electricity to load form battery AC", "electricity to load form Grid AC" and "electricity to load form system AC" in the time series. I can see from this graph which electricity (grid or system or battery) was used for the total power consumption. But if I compare this graph with "system power generated", I can see that the power generated is more than the amount stored in the battery. So is there any parameter that can tell me if the power generated by the system is stored in the battery and where the remaining power was used? If there is, please let me know.
And please give me feedback if my parameters chosen for comparing the results according to the battery operation options under the same conditions are correct! Also If there are any other parameters (result data) that can be shown additionally, I would be grateful to know.
Thank you
Thank you
28 Mar 2024 14:15 #13034
Replied by Paul Gilman on topic Generic-Battery System data table
Hi Dawon,
SAM accounts for losses in the system, including thermal losses from the battery as the battery charges and discharges. I think these losses account for the difference between the power values that you see.
