How to build the diagram of the wave energy converter with my own data
- Juan Diego Diaz Alvarez
08 Mar 2024 17:17 #12968
by Juan Diego Diaz Alvarez
How to build the diagram of the wave energy converter with my own data was created by Juan Diego Diaz Alvarez
I have the data and when us the guide diagrams tha SAM have, I build my own diagram, but the program sends me an error when simulating in which that I'm confused, and I haven't idea to sort out. The error is the next one.
exec fail(mhk_wave): The wave conditions at timestep0were not able to be located in the power matrix. Please check your resource file
Simulation mhk_wave failed :exec fail(mhk_wave): The wave conditions at timestep0were not able to be located in the power matrix. Please check your resource file
exec fail(hourly_energy_calculation): invalid number of gen records (8763): must be an integer multiple of 8760
Simulation singleowner failed :exec fail(hourly_energy_calculation): invalid number of gen records (8763): must be an integer multiple of 8760Please help me with this error, and how to fix it.
11 Mar 2024 11:08 #12969
Replied by Paul Gilman on topic How to build the diagram of the wave energy converter with my own data
Hi Juan,
Please attach a copy of the .csv file you are using for your wave resource data if you would like me to help troubleshoot.
12 Mar 2024 17:38 #12977
Replied by Juan Diego Diaz Alvarez on topic How to build the diagram of the wave energy converter with my own data
Thanks to the help the .csv that have the name of San_Andres_WEC is the one with the error and also I send you the .csv of the Wave Resource (lat12.63_lon-81.63_2020.csv) that is the complement of the .csv of the WEC
13 Mar 2024 16:06 #12979
Hi Juan,
Thank you for sending the files.
The frequency of occurrence "San_Andres_WEC.csv" file needs two header rows above the resource data rows. In the attached "San_Andres_WEC.csv" file, I added those rows with empty data to get SAM to recognize the file. You can use a zero for any headers that you do not have data for.
The time series "lat12.63_lon-81.63_2020.csv" file needs time stamps from January 1 to December 31. For example, for three-hour data, the first time stamp might be 2013/1/1 0:0 and the last one 2013/12/31 0:21. The time stamps in your file start with 2013/6/1 0:0 and end with 2014/7/19 0:0. There is also one extra row in your file: For three-hour data, the total number of rows including headers should be 2923, your file has 2924. Perhaps you could rearrange the data to start with January 1 2014 and end with December 31 2013.
22 Mar 2024 17:35 #13019
HI Paul
Thanks for the help but I have a question about how the WEC is built since the document they provided me did not work for me although I managed to deduce some things and built another one which will no longer generate an error, even so I am going to send it to you to see if Help me to have more data or see if you can explain to me through a report or a message what the construction of the WEC file is like.
Stay tuned to your comments.
Juan Diego.
Juan Diego.
28 Mar 2024 14:25 #13036
Hi Juan Diego,
You can find a description of the marine energy resource file formats in Help: samrepo.nlr.gov/help/weather_format_csv_marine_energy.html
You can also find examples of the files in the 'wave_resource' folder your SAM installation folder ('C:/SAM/2017.12.23' by default in Windows). For examples of time series wave resource data, see the 'wave_resource-ts' folder.
The file you attached is missing the first two header rows. You can copy and paste those rows from one of the files in the 'wave_resource' folder.
Paul
Paul
