Error when using 3D shade calculator
- Nils Jernsäter
28 Feb 2024 05:47 #12951
by Nils Jernsäter
Error when using 3D shade calculator was created by Nils Jernsäter
Hello,I´m using SAM to assess the possibilities for a solar panel installation on a customer's roof. When using the 3D shade calculator to evaluate the impact of surrounding objects on the solar panel system, I encountered the following error code:
"could not evaluate callback function:edit_3d_scene->on_change
[161]: error in call to´value():data type mismatch attempting to set ´subbarray1_shading´(number).. etc etc. (See attached file)Do you know what might be causing this issue?(using: SAM 2023.12.17)
28 Feb 2024 10:33 #12954
Replied by Paul Gilman on topic Error when using 3D shade calculator
Hi Nils,
This is a bug that we have fixed for the first update to SAM 2023.12.17, which we hope to release next week.
For a description and workaround solution, see:
github.com/NREL/SAM/issues/1678
