Battery Dispatch "Retail rate dispatch" yields error
- Erazem Zver
20 Feb 2024 09:19 #12923
by Erazem Zver
Battery Dispatch "Retail rate dispatch" yields error was created by Erazem Zver
Hello, I am trying to get the Retail rate dispatch (price signals dispatch) to work.
When I try running it, I get this error:
I have tried changing a few things, but the error is persisting. It looks like this error was once before "corrected" according to git:
Monthly TOU periods don't work for price signals forecast · Issue #843 · NREL/ssc · GitHub
I however, can not get this Battery Dispatch option to work.
Documentation on this error is sparse. I can not find any relevant forum posts, that would outline the solution.
I have attached the project I am trying this to get to work on.
Thanks for the help.
exec fail(lib_utility_rate_equations): Demand rate Period 1 not found for Month 2.
Simulation pvsamv1 failed :Calculated negative global horizontal irradiance of -1.4559 W/m2 at time [y:20814 m:7 d:15 h:18 minute:30], set to zero.
monthly_grid_to_batt not assigned
Simulation cashloan failed :monthly_grid_to_batt not assigned
20 Feb 2024 20:19 - 20 Feb 2024 20:19 #12926
Replied by Paul Gilman on topic Battery Dispatch "Retail rate dispatch" yields error
Hi Erazem,
Thank you for letting us know about this issue. We will fix it in github.com/NREL/ssc/issues/1134 .
Unfortunately, I don't know of a workaround solution.
I agree this is related to github.com/NREL/ssc/issues/843 , but this is a different issue that will need to be fixed.
Last edit: 20 Feb 2024 20:19 by Paul Gilman.
