SCA Length
- sidom
14 Mar 2013 08:56 #1440
by sidom
SCA Length was created by sidom
Working with SAM CSP physical model,I have been reading the decription of the following parameters but I am a bit confused about the scope of both parameters:
- Length of collector assembly
- Piping distance between assemblies
Could you please be more accurate about the battery limits of these parameters?
Thank you in advance
05 Apr 2013 16:20 #1441
Replied by Paul Gilman on topic SCA Length
The "length of collector assembly" is simply the length of the SCA. The description in Help is confusing, and I will revise it for the next version of SAM.
The "piping distance between assemblies" is the length of pipe that connects two adjacent SCAs in a loop.
In the loop configuration diagram on the Solar Field page, the length of collector assembly is represented by the length of one of the rectangles representing a collector, and the piping distance between assemblies is represented by the length of the red or blue line that connects two of the rectangles.
