Generic System
- dawon
13 Feb 2024 23:32 #12889
by dawon
Generic System was created by dawon
I recently integrated two PV models using the Generic System model and now I'm planning to integrate the combined PV model with an Energy Storage System (ESS). Therefore, I first want to know if this is possible. Also, I tried combining two PV models using the Generic System model, but the power generation was lower than the sum of the power generation from each PV model. Could you please explain the reason for this? I would appreciate it if you could also explain the principle behind it.
The method for the task I want to accomplish is as follows.
PV_1 model +PV_2 model > PV_alpha model
PV_alpha model +Generic system battery model > PV+battery model
14 Feb 2024 17:35 #12891
Replied by Paul Gilman on topic Generic System
Hi Dawon,
You can use the Generic-Battery performance model to model a battery that responds to a power generation profile that you provide as input.
Be sure to set the Generic System model's plant loss input to zero -- I think that may explain the reduction in power generation you observed.
