Power generation error
- dawon
13 Feb 2024 23:26 #12888
by dawon
Power generation error was created by dawon
I am using SAM's Residential Owner model to estimate power generation. I used the same equipment conditions and TMY data. Upon comparing the estimated power generation with the actual generation data I have for one year, I found that the results are different. Of course, I understand that there will be errors because I used TMY and the equipment conditions do not perfectly match. However, I want to obtain power generation data that is as similar (almost identical) as possible. So, I am wondering if there's a way to input one year's worth of generation data and have it extracted as is.
14 Feb 2024 17:37 #12892
Replied by Paul Gilman on topic Power generation error
Hi Dawon,
If you have measured power generation data, or power generation data from another model, you can use the Generic System or Generic System-Battery model to use that data as input.
