Power consumption of solar tracker
- Anh
05 Feb 2024 06:15 #12866
by Anh
Power consumption of solar tracker was created by Anh
hi colleagues,
I am doing a simulation of a tracking solar system (horizontally single axis). There is a question about the power consumption of a solar tracker that I would like to ask. As far as I understand, the solar tracker will use the power generated from the solar panel.
Can anyone please tell me further about the method to estimate the power consumption of a solar tracker?
I look forward to hearing from you.
Kind regards,
Anh
Kind regards,
Anh
05 Feb 2024 09:48 #12867
Replied by Paul Gilman on topic Power consumption of solar tracker
Hi Anh,
SAM does not model power consumption for solar trackers. You can account for tracker power as a loss by adjusting the DC loss on the Losses page.
Tracking error loss accounts for failure of the tracker to correctly orient the modules, and is another factor to consider. SAM assumes that the tracker follows the movement of the sun perfectly. You can use a DC loss to account for tracking error. This article discusses tracking error:
K. Anderson, C. Downs, S. Aneja and M. Muller, " A Method for Estimating Time-Series PV Production Loss From Solar Tracking Failures ," in IEEE Journal of Photovoltaics, vol. 12, no. 1, pp. 119-126, Jan. 2022.
- Anh
06 Feb 2024 07:11 #12871
by Anh
Replied by Anh on topic Power consumption of solar tracker
hi Paul, Thanks for your information.
