Minimum DNI for start up MS SPT model
- Harry Morgan
30 Dec 2023 09:52 #12786
by Harry Morgan
Minimum DNI for start up MS SPT model was created by Harry Morgan
Hi Paul/NREL
When running the annual simulations, I believe I am correct in saying that the model varies HTF flow rate to achieve the desired outlet temperature based on the DNI and resultant incident flux on the receiver.
However, how does the model specify a minimum DNI for production of hot salt? if so, what is this value and can I change this?
Kind regards
Harry
Kind regards
Harry
02 Jan 2024 16:24 #12788
Replied by Paul Gilman on topic Minimum DNI for start up MS SPT model
Hi Harry,
I'm not sure I understand your question. Can you clarify what you mean by "for production of hot salt?" The model attempts to maintain the HTF (molten salt in this case) temperature between the hot and cold temperature inputs on the System Design page.
- Harry Morgan
03 Jan 2024 06:23 #12798
by Harry Morgan
Replied by Harry Morgan on topic Minimum DNI for start up MS SPT model
Thanks for getting back to me. Sorry about that, what I meant was, how does the performance model "decide" when to start/stop the heating of HTF. I had assumed it was based on a minimum instantaneous DNI, but I had a more thorough look through, and I believe it is done by specifying a minimum flow rate, is that correct?
IF so I am assuming the model calculates the flowrate of HTF required to yield the outlet temperature, and if the DNI and hence flux on the receiver are so low that the flowrate would be below the specified lower bound, then the process is non operational for that hour?
IS that at all correct Paul? if not, please could you correct me?
Harry
Harry
18 Jan 2024 13:46 #12834
Hi Harry,
One way to control the minimum receiver operation is by adjusting the input “Minimum receiver turndown fraction” on the Tower and Receiver page.
SAM applies this fraction to the incident (after reflection losses) flux:
Minimum incident flux = Design thermal power absorbed by HTF * Min Receiver Turndown Fraction / 0.9
Where 0.9 is an estimate for receiver thermal efficiency.
The effect of this is very similar to setting a minimum on the HTF mass flow rate.
