Set desired water temperature for solar thermal model?
- Jarett Diamond
05 Mar 2013 11:56 #1388
by Jarett Diamond
Set desired water temperature for solar thermal model? was created by Jarett Diamond
I want to model a solar thermal collector system which produces up to 170 degF hot water. Is it possible to set a custom desired hot water temperature in SAM? Can this desired hot water be given different values for each month?
Thank you.
Thank you.
05 Mar 2013 12:48 #1389
Replied by Paul Gilman on topic Set desired water temperature for solar thermal model?
Dear Jarett,
The "Auxiliary Set Temp" determines the temperature of water delivered by the system. It is not possible to specify a different set temperature for each month.
- Jarett Diamond
08 Mar 2013 08:50 #1390
by Jarett Diamond
Replied by Jarett Diamond on topic Set desired water temperature for solar thermal model?
If my auxiliary system is a tankless hot water heater, what value should I list for Auxiliary Volume? Should I list the same as the Solar Tank Storage Volume?
