PV-battery commercial: monthly_grid_to_batt not assigned
- Alessio Sitti
25 Sep 2023 12:20 #12514
by Alessio Sitti
PV-battery commercial: monthly_grid_to_batt not assigned was created by Alessio Sitti
Hello everyone,
I'm trying to run a PV-battery project. I set the system as an AC connected; the BTM, in the battery dispatch menu, is set on "input grid power target". Simulation ends with the following error:
Simulation cashloan failed :monthly_grid_to_batt not assigned.
Values of "monthly grid power targets" in Battery dispatch are assigned: they are set as 1 and I also tried setting them as 10.
How can I solve this problem? How to correctly configure the setup?
Thank you
Thank you
27 Sep 2023 13:35 #12516
Replied by Paul Gilman on topic PV-battery commercial: monthly_grid_to_batt not assigned
Hi Alessio,
Please attach a copy of the .sam file that generates this error if you would like me to help troubleshoot.
- Alessio Sitti
28 Sep 2023 02:29 #12518
by Alessio Sitti
Replied by Alessio Sitti on topic PV-battery commercial: monthly_grid_to_batt not assigned
the file is already attached in the message. Anyway here it is again.
SAM version 2022.11.21
Thank you.
Best regards.
Alessio
Thank you.
Best regards.
Alessio
