Solar Water Heating Total Area Equation Units
- Kurban Sitterley
10 Jul 2023 11:01 #12306
by Kurban Sitterley
Solar Water Heating Total Area Equation Units was created by Kurban Sitterley
I am trying to calculate the total collector area required for a solar water heating system using a surrogate model I created with PySAM.
The documentation has:
Can you explain how you get the proper units from this equation? What are the units for FRta and/or what are the units for the 0.03 factor? On my side, I can get my model to match SAM output if I convert capacity to kW, assign kW/m2 to FRta and units of K to the 0.03 factor, and convert FRUL to kW/m2, but I would prefer to know the details behind this calculation.
- Nameplate Capacity = Total collector area * (FRta - FRUL * 0.03)
- Nameplate Capacity [kW]
- Total collector area [m2]
- FRta [dimensionless]
- FRUL [W/m2]
- 0.03 [????]
12 Jul 2023 16:38 #12321
Replied by Paul Gilman on topic Solar Water Heating Total Area Equation Units
Hi Kurban,
I agree that the dimensions don't seem to make sense. The equation in the SAM user interface for the solar water heating model system capacity is:
system_capacity = area_coll * ncoll * ( FRta - FRUL * ( 30 / 1000 ) )
For what it's worth, this system_capacity value is not used in the solar water heating performance model simulation except to calculate the capacity factor. It is used by the financial model to calculate any costs or incentives specified in $/kW.
We don't have a developer working on the solar water heating model for the moment, but I will see if I can get an answer to this and follow up.
07 Aug 2023 13:31 #12382
Hi Kurban,
There is an implied multiplication of FRta by 1000 W/m2:
system_capacity [W] = total_collector_area [m2] * ( FRta [] * 1000 W/m2 - FRUL [W/m2-C] * 30 [C] )
Converting to kW:
system_capacity [kW] = total_collector_area [m2] * ( FRta [] * 1 kW/m2 - FRUL [W/m2-C] * 30 [C] / 1000 W/kW )
The rated system size equation is derived from Equation 2.1.4 of the draft technical manual and assumes an irradiance of 1000 W/m² and temperature difference of 30°C.
DiOrio, N.; Christensen, C.; Burch, J.; Dobos, A. (DRAFT 2014). Technical Manual for the SAM Solar Water Heating Model. ( PDF 150 KB )
We will revise the description in Help to make that clearer.
For more information about SAM's solar water heating model, see:
sam.nlr.gov/solar-water-heating.html
samrepo.nlr.gov/help/solar_hot_water.html
Converting to kW:
