discrepancy in the results obtained
- IGOR CARMELO SANGIORGIO
20 Jun 2023 04:20 - 20 Jun 2023 22:56 #12240
by IGOR CARMELO SANGIORGIO
discrepancy in the results obtained was created by IGOR CARMELO SANGIORGIO
Good morning,
I would like to ask some information about the formula SAM uses to calculate the 'Array POA rear side direct and diffuse radiation after (IAM)'. In fact how I show in the picture below in some cases the first value of certain days seems to be out of scale in comparison with the data of the hours after.
In the same hour the sum of the 'Array POA rear side direct and diffuse radiation after (IAM)', the Array POA rear side radiation reflected from the ground after (IAM)' and of the 'Array POA rear side radiation reflected from the rear row after (IAM)' does not match with the value reported in Array POA rear side total radiation after reflection (IAM)'; unlike all the other moments of the day.
Last edit: 20 Jun 2023 22:56 by Paul Gilman.
12 Jul 2023 10:36 #12316
Replied by Paul Gilman on topic discrepancy in the results obtained
Hi Igor,
I'm having trouble replicating the results you describe. Please attach a .sam file that demonstrates these results. Also, to include images in your post, please attach each image as a file and then insert it into the post.
