Uncertainty simulation: Error while computing samples using LHS
- Heduardo
12 Jun 2023 15:02 #12210
by Heduardo
Uncertainty simulation: Error while computing samples using LHS was created by Heduardo
I wanted to run an uncertainty simulation with 60 minute and 30 minute data but keep receiving the same error message:
"An error ocurred while computing the samples using LHS:
Could not read output file var/folders/sy/1qs4snwj1g5ft5zzz14gzwzr0000gn/T/SAMLSH.LSP "
I am running the SAM version 2022.11.21, 64bit.
SSC version 280: OS X 64 bit GNU/C++
wxWidgets 3.2.0 on macOS Monterrey version 12.6.6 (Build 21G646)
I have been able to run the uncertainty analysis with no problem on other computer with the very same data files.
Thanks!
Heduardo
Thanks!
Heduardo
- sjanzou
13 Jun 2023 01:16 #12211
by sjanzou
Replied by sjanzou on topic Uncertainty simulation: Error while computing samples using LHS
Heduardo,
Thanks for reporting this issue. We have duplicated your failing results on MacOS.
Please track progress on this issue at github.com/NREL/SAM/issues/1417
- Simon Sandler
17 Apr 2024 13:27 #13091
by Simon Sandler
Replied by Simon Sandler on topic Uncertainty simulation: Error while computing samples using LHS
I have come across the same error while running an uncertainty model:"An error occurred while computing the samples using LHS:Could not read output file /var/folders/yg/t3lyshyd56zdhzznvf6d18mssz8fgv/T/SAMLHS.LSP"I am running on a Mac, MacBook Pro, M1 chip, OS 13.6.6Version 2023.12.17, 64 bit, updated to revision 1SSC Version 290: OS X 64 bit GNU/C Mar 7 2024 03:31:21I have gotten this to occur across multiple weather files, but I am attaching one.
17 Apr 2024 13:37 #13092
Replied by Paul Gilman on topic Uncertainty simulation: Error while computing samples using LHS
Hi Simon,
Thank you for letting us know about this.
The Uncertainty simulations don't work on Mac and Linux versions of SAM:
github.com/NREL/SAM/pull/1504
Unfortunately, we don't have a solution for this yet, but are working to find one.
- Simon Sandler
18 Apr 2024 09:04 #13100
by Simon Sandler
Ok, this makes sense now. I didn't understand the github timeline.
Appreciate the support and I'm excited about this feature when a solution is discovered.
