Error trying to run weather data file for wind
- Daniel
08 May 2023 08:12 #12124
by Daniel
Error trying to run weather data file for wind was created by Daniel
Good day
I am trying to run a weather data file, I put it in the format as found on the SAM help system in the software.
I get the following error:
exec fail(windpower): failed to read local weather file: file stream error reading file, C:/Users/danny/OneDrive/Desktop/SAM_Data/WM05_FINAL.csv
Simulation windpower failed :exec fail(windpower): failed to read local weather file: file stream error reading file, C:/Users/danny/OneDrive/Desktop/SAM_Data/WM05_FINAL.csv
gen not assigned
SSC requires input 'annual_energy', but was not found in the SAM UI or from previous simulations
Simulation lcoefcr failed :precheck input: variable 'annual_energy' (Annual energy production) required but not assigned
It is a .csv fie.
Kind regards
Daniel
gen not assigned
It is a .csv fie.
Kind regards
Daniel
08 May 2023 16:42 #12127
Replied by Paul Gilman on topic Error trying to run weather data file for wind
Hi Daniel,
Please attach a copy of the CSV file you are trying to use if you would like me to help troubleshoot.
