Annual produced energy lower than expected
- Lucas
04 Apr 2023 14:27 #12033
by Lucas
Annual produced energy lower than expected was created by Lucas
Hey Paul!
I've been trying to run a csp tower plant and I've been struggling a lot with the obtained results. The cicle is designed to produce 100MWe but converting the annual produced energy Im obtaining something close to 22MW. I have already ultilized a solar multiple of 3 and also increased the hours of storage but still nothing more than this..
Is there a way that I can share my imputs for some evaluation or maybe some guidance regarding what I have missed?
Thanks!
Thanks!
04 Apr 2023 16:20 #12034
Replied by Paul Gilman on topic Annual produced energy lower than expected
Hi Lucas,
You can attach your .sam file if you would like me to try to help troubleshoot.
The image you attached shows peak output of 120 MW and a capacity factor of almost 79%, which is different from what you describe.
- Lucas
05 Apr 2023 08:14 #12036
by Lucas
Replied by Lucas on topic Annual produced energy lower than expected
Hey Paul!
I had tried to run the SAM Macro but since the I didnt manage to change the code in a way that I could reach the HTF leaving the PHX at 290°C, I ended up changing the cold temperature manually..
Also, regarding my results It must have to do with my lack of experience on this subject but the approach I tried to describe was that when I take the annual production as a reference and convert into a hour basis I was getting an output quite smaller than the desired (100MWe).
I also noticed that during few days the plant is not producing (negative output) which got my wondering if my results are indeed solid or not.
Im using this simulation (mainly the mass flow rate) as part of my masters so thats why I need to know if my results are consistent with reality or if there is something Im missing!
Thanks for your help.
My latest file follows attached.
