Autonomous Calculations
- Matthew
14 Mar 2023 08:42 #11994
by Matthew
Autonomous Calculations was created by Matthew
I've setup my SAM model to represent a PV+Battery system that I want to evaluate for sustaining a critical load (that happens to equal 100% of load during the year). As such, it seems the Autonomous Calculations would provide this output ([url] samrepo.nlr.gov/help/index.html?grid_outage.html [/url]). However, in running the simulation, SAM is now 'bogged' down (this happened somewhere around 65% simulating progress, if that helps),... the simulation took maybe an hour or two to get in the 60's, but I'm currently at ~86% simulation progress after an additional ~84 hours on my computer, with little end in sight. Is this kind of simulation time expected for my described setup??
Thank you for your help!
14 Mar 2023 16:48 #11997
Replied by Paul Gilman on topic Autonomous Calculations
Hi Matthew,
A SAM simulation should not take that long -- even with battery dispatch and grid outage calculations over the analysis period, the simulation run time should be on the order of minutes, not hours.
Please attach a copy of your .sam file if you would like me to help troubleshoot.
- Matthew
16 Mar 2023 19:09 - 21 Mar 2023 09:50 #12001
by Matthew
Replied by Matthew on topic Autonomous Calculations
I sent the SAM file to sam.support@nlr.gov for your review.
Thank you for your support,
Matthew
Matthew
Last edit: 21 Mar 2023 09:50 by Paul Gilman.
