Ground Irradiance
- Daniel Marshal
01 Feb 2023 03:02 #11891
by Daniel Marshal
Ground Irradiance was created by Daniel Marshal
Hi all,
in SAM 2022.11.21, there are new updates about output for ground Irradiance. Can I get equation refference for this output. I checked the PV Technical Refference ( www.nlr.gov/docs/fy18osti/67399.pdf ) but can't find the related equation.
nb: Following variable that I mention as ouput :
- Irradiance incident on the ground within array
- Irradiance absorbed by the ground within the array
- Array POA rear_side radiation reflected from the ground after (IAM)
Thanks !
Thanks !
- RANIA BENBBA
23 Oct 2024 18:13 #13547
by RANIA BENBBA
Replied by RANIA BENBBA on topic Ground Irradiance
This message contains secure information
24 Oct 2024 14:52 #13553
Replied by Paul Gilman on topic Ground Irradiance
A description of the ground irradiance and rear irradiance calculations is available in the following document and code repository:
research-hub.nlr.gov/en/publications/viewfactor-and-raytracing-for-agripv-modeling
github.com/NREL/bifacialvf
