NEM 3.0 in California
- Ricky
10 Jan 2023 18:31 #11825
by Ricky
NEM 3.0 in California was created by Ricky
Hello. As far as I can see, the rate structure for NEM 3.0 in California isn't available to upload into SAM v. 2022.11.21. Is this correct? It seems the U.S. Utility Rate Database hasn't been updated for a while. If it is the case that NEM 3.0 rate structure can't be uploaded into SAM, are you able to advise when it will be available, and what the best current work-around might be?
12 Jan 2023 16:49 #11828
Replied by Paul Gilman on topic NEM 3.0 in California
Hi Ricky,
SAM downloads data from the The Utility Rate Database (URDB) at openei.org/wiki/Utility_Rate_Database .
The database generally includes data from utility rate sheets, and not always net metering and other regulations that determine the sell rate or net metering option.
Until the URDB is updated, you will need to enter the appropriate sell rates for NEM 3.0 yourself.
In general, you should always review the data imported from the URDB to make sure it matches the rate sheet data.
