Heliostat Model Validation
- Lucas
03 Jan 2023 10:53 #11793
by Lucas
Heliostat Model Validation was created by Lucas
Hey!
Im using the same data to build a heliostat field on both SolarPILOT and SAM. Therefore in SOLAR Pilot Im having around 100 additional heliostats in comparison with my heliostat field in SAM
Can I expect a difference like this when comparing both softwares?
Also, when validating the heliostat performance in SAM, can I consider "Receiver thermal power to HTF less piping loss"as an equivalent result for the "power absorbed by HTF" in SolarPILOT ?
Thanks!
Thanks!
03 Jan 2023 11:57 #11794
Replied by Paul Gilman on topic Heliostat Model Validation
Hi Lucas,
SAM does not provide access to all of the SolarPILOT inputs, so I would expect some differences in results between SAM and SolarPILOT because of differences in the inputs.
SolarPILOT does not have a piping model, so I would not expect the SolarPILOT "Power absorbed by HTF" to be equivalent to SAM's "Receiver thermal power to HTF less piping loss."
- Lucas
03 Jan 2023 12:00 #11795
by Lucas
Replied by Lucas on topic Heliostat Model Validation
Hey Paul! thanks for your quick reply..
but still, by only validating SAM and forgetting about the differences, can I consider "Receiver thermal power to HTF less piping loss.""as the power absorbed by the HTF?
03 Jan 2023 12:02 #11797
Hi Lucas,
Yes, SAM's "Thermal power to HTF less piping loss" is the heat absorbed by the HTF in the receiver.
- Lucas
03 Jan 2023 12:10 #11798
by Lucas
Thanks once again Paul!
05 Jan 2023 09:21 #11809
Hi Lucas,
One more note is that you can export the heliostat field layout from either SAM or SolarPILOT to and import it to the other to help make the inputs as consistent as possible.
