how to calculate thrust coefficient, power coefficient and turbulence intensity?
- Hamza Ali
17 Nov 2022 23:02 #11707
by Hamza Ali
how to calculate thrust coefficient, power coefficient and turbulence intensity? was created by Hamza Ali
Hello sir, can you please explain how to calculate thrust coefficient, power coefficient and turbulence intensity?
Thrust coefficient formula is CT = 4a(1-a) equation 32 in wind SAM manual.
How to get the value of unknown variable "a", where a = axial induction factor.
In turbulence intensity formula equation 34, How to get the value of unknown variable "x", where x = cross wind distance between turbines in rotor radii. ??
Can you reply me as earliest as possible please!
28 Nov 2022 12:09 #11734
Replied by Paul Gilman on topic how to calculate thrust coefficient, power coefficient and turbulence intensity?
Hi Hamza Ali,
Section 8.2.1 of the SAM wind reference manual describes the code in the turbinePower() function here:
github.com/NREL/ssc/blob/7b84c5b5eb73ab77bc72e081277c6c27a3a00f31/shared/lib_windwakemodel.cpp#L71
Specifically, the thrust coefficient and power coefficient equations are here:
github.com/NREL/ssc/blob/7b84c5b5eb73ab77bc72e081277c6c27a3a00f31/shared/lib_windwakemodel.cpp#L123
The turbulence intensity equations described in Section 8.2.2 are here:
github.com/NREL/ssc/blob/7b84c5b5eb73ab77bc72e081277c6c27a3a00f31/shared/lib_windwakemodel.cpp#L142
