CSP Parabolic Trough Physical - Power Cycle Queries
- Javier Pastoriza
14 Nov 2022 00:51 #11688
by Javier Pastoriza
CSP Parabolic Trough Physical - Power Cycle Queries was created by Javier Pastoriza
Dear Paul:
A few queries on the power cycle behavior I could observe running the default configuration on SAM 2021.12.2:
1. Start-up time of 0.5 h seems to be not considered in a simulation with 1h time step. Start-up power is maintained for the whole time steps using more energy for the start-up process than required as per user inputs.
2. Although user sets min/max ST load on the GUI, these limits seem to apply to the PC inlet thermal power as per current implementation.
3. Start-up power seems to be factored in by reducing the PC efficieny (not deducted from the PC inlet thermal power); therefore, the PC operates below the min load as per user inputs, this happens both in terms of inlet thermal power and ST gross power.
4. It seems that the PC operates below the min load in moments where start-up is not taking place, this happens both in terms of inlet thermal power and ST gross power.
5. Could the change in material/HTF internal energy from SF to TES and PC be reported as output? As it is done for the SF piping.
6. Abrupt drop in "PC HTF Inlet Temperature" in last time step being the PC operative from TES only. It does not happen always but it happens frequently. Why?
7. PC does not go to stand-by in any time step. Conditions under which the PC goes to stand-by?
I would be thankful if you could assist me with them. I do have my analysis ready to be shared in case of help. Thanks.
Javier Pastoriza.
Javier Pastoriza.
14 Dec 2022 13:10 - 14 Dec 2022 13:14 #11778
Replied by Paul Gilman on topic CSP Parabolic Trough Physical - Power Cycle Queries
Hi Javier,
Question 1: Start-up time of 0.5 h seems to be not considered in a simulation with 1h time step. Start-up power is maintained for the whole time steps using more energy for the start-up process than required as per user inputs.
The "Fraction of thermal power needed for startup" value is poorly labeled. A better label would probably be “fraction of an hour at design point thermal required for startup energy”. The equation is:
Energy_startup = q_dot_des * 1 (hr) * fraction_input (-)
So, in the default case:
Energy_startup = 311.80 * 0.2 (hr) = 62.36 (MWt-hr)
The 0.5 hr is the minimum startup time. In the first time step, where TES is available, the controller sets the thermal power
to achieve startup in the minimum time:
q_dot_su = 62.36 / 0.5 hr = 104.72 MWt
However, q_dot_startup, like most rate outputs, is reported as weighted value over the full hourly time step. q_dot_startup in the second time step (from 0.5 hr to 1 hr) is = 0, therefore:
q_dot_startup_timestep = 0.5*(104.72 + 0) = 62.36 MWt
Since this term is supposed to represent the average q_dot_startup over the entire time step, it makes sense that it matches the startup energy in this case.
Question 2: Although user sets min/max ST load on the GUI, these limits seem to apply to the PC inlet thermal power as per current implementation.
Yes, the controller uses the “turbine fraction” to adjust heat input rather than power output.
Question 3: Start-up power seems to be factored in by reducing the PC efficiency (not deducted from the PC inlet thermal power); therefore, the PC operates below the min load as per user inputs, this happens both in terms of inlet thermal power and ST gross power.
This is incorrect. Startup power requirements are taken from the inlet thermal power for the needed fraction of the time step, and this can be seen with the startup thermal energy output not having the same value over the 1 hr time step. After startup, the power cycle may operate for the remainder of the time step.
Question 4. It seems that the PC operates below the min load in moments where start-up is not taking place, this happens both in terms of inlet thermal power and ST gross power.
We were not able to reproduce these results. Please attach a .sam file that demonstrates this so we can investigate.
Last edit: 14 Dec 2022 13:14 by Paul Gilman.
- Joe
09 Jun 2025 20:04 #14106
by Joe
Replied by Joe on topic CSP Parabolic Trough Physical - Power Cycle Queries
Hello, Paul,
I have same problem about question 2. You can find that it will have the same output result(the gross power will be more than 100% rated turbine power) however you set "the maximum turbine over design operation=1" in Power cycle Page or you set the "turbine output fraction=1" of the dispatch control in System Control. you can try and simulate the example we send.
Thank you for your help.
Looking forward to your reply.
Joe
Joe
- Ty Neises
03 Jul 2025 10:25 #14144
by Ty Neises
Replied by Ty Neises on topic CSP Parabolic Trough Physical - Power Cycle Queries
Hi Joe,
I think the issue is that the plant controller model currently uses these fractions to control the heat input to the cycle, not the cycle power generation directly. As such, when off-design conditions like the ambient temperature change in a way that increases the cycle efficiency relative to the design-point, the cycle output power will increase for a constant heat input.
We are working on an option to control plant operation to achieve a target system net power output, and we hope to include it in the fall release for at least the power tower model.
