CSP Parabolic Trough Physical - Field Collector Optical Efficiency
- Javier Pastoriza
09 Nov 2022 05:23 #11669
by Javier Pastoriza
CSP Parabolic Trough Physical - Field Collector Optical Efficiency was created by Javier Pastoriza
Dear Paul:
The variable "Field Collector Optical Efficiency" reported as output cannot be replicated applying Eq.2.43 of the Technical Manual for the SAM Physical Trough Model using as terms of the equation the arrays reported as outputs of the simulation (end loss*shadow*IAM *tracking*geometry*reflectance*soiling*general efficiencies). Adding cosine efficiency to the product does not solve the issue neither. The reported "Field Collector Optical Efficiency" is lower than the value one can applying Eq.2.43. See attachment please (columns S & T in particular)
Is a different formulation actually implemented in the code? If that is the case, how does it look like?
Thanks for your support.
Javier Pastoriza.
Javier Pastoriza.
- Javier Pastoriza
10 Nov 2022 07:50 #11677
by Javier Pastoriza
Replied by Javier Pastoriza on topic CSP Parabolic Trough Physical - Field Collector Optical Efficiency
Hi Paul:
I managed to verify that the field optical efficiency is implemented as follows on SAM 2021.12.2: "Field Optical Efficiency Before Defocus" = End Loss * Row Shadowing * IAM * Tracking * Geometry * Reflectance * Dir on Mirror * General Optic Error * Bellows Shadowing * Dirt on Receiver * Envelope Transmittance * Absorber Absorptance * Deploy/Stow Time Fraction.
The formulation is now clear to me so I think we can close this topic. Thanks a lot in case you already dedicated some time to this query.
Javier Pastoriza.
Javier Pastoriza.
