CSP Parabolic Trough Physical - SF HTF (Oil) Mass Flow Balance
- Javier Pastoriza
04 Nov 2022 05:19 #11654
by Javier Pastoriza
CSP Parabolic Trough Physical - SF HTF (Oil) Mass Flow Balance was created by Javier Pastoriza
Dear community:
I've been trying to close the SF HTF (Oil) mass flow balance ("Field HTF mass flow rate total" = "TES HTF mass flow rate - field side of HX" + "Cycle HTF mass flow rate") but I continuously get inconsistent results. The Excel file shared illustrates the issue, the balance is presented in column AJ.
Any idea of what is going on? Thanks!
Javier Pastoriza.
Javier Pastoriza.
07 Nov 2022 16:01 #11664
Replied by Paul Gilman on topic CSP Parabolic Trough Physical - SF HTF (Oil) Mass Flow Balance
Dear Javier,
Please see this related posts and let me know if it resolves your question:
sam.nlr.gov/component/kunena/forum-general/1036
- Javier Pastoriza
07 Nov 2022 23:02 #11667
by Javier Pastoriza
Replied by Javier Pastoriza on topic CSP Parabolic Trough Physical - SF HTF (Oil) Mass Flow Balance
Thanks Paul for your answer.
I understand SAM uses iterative algorithms and convergence error are part of them, that is natural. However, my query still remains given the relative error magnitude, at time step level, I can see on the SF HTF mass balance calculated using the variables presented in my initial query. I would like to take it forward differentiating different operation scenarios if you allow me.
(1) SF Off + TES Discharging + Cycle On: min rel. error = 0% / max rel. error = 0%
(2) SF On + TES Discharging + Cycle On: min rel. error = -0.10% / max rel. error = 0.09%
(3) SF On + TES Idle + Cycle On: min rel. error = -0.08% / max rel. error = 35.54%
(4) SF On + TES Charging + Cycle Off: min rel. error = 0% / max rel. error = 94.24% (single time step)
(5) SF On + TES Charging + Cycle On: min rel. error = -4.60% / max rel. error = 33.35%
The relative error size makes me think we are facing something else than convergence errors. I could be missing or misinterpretating the problem.
Warm regards.
Javier Pastoriza.
Warm regards.
Javier Pastoriza.
09 Nov 2022 09:16 #11672
Hi Javier,
Attached is an Excel file that shows the mass balance for the physical trough model.
- Javier Pastoriza
09 Nov 2022 22:37 #11675
by Javier Pastoriza
Thanks Paul, the balance works fine in the file you shared, no question. May I know the software version used to get this balance?
Nevertheless, the balance issue I have presented can be easily replicated when using the version 2018.11.11 just running the default case of the Trough Physical Model.
Javier Pastoriza.
Javier Pastoriza.
12 Nov 2022 16:11 #11686
Hi Javier,
I believe my colleague used SAM 2021.12.02 to generate the data in the Excel file.
