Importing measured data file
- Cia
06 Feb 2023 02:06 #11901
by Cia
Replied by Cia on topic Importing measured data file
Thank you for your swift reply Paul, that's much appreciated!
All clear now
All the best!
All clear now
All the best!
- zskold@kth,se
22 Feb 2023 02:47 #11949
by zskold@kth,se
Replied by zskold@kth,se on topic Importing measured data file
Hello! I have created a weather file for my application in Sweden with all the required data for a detailed PV model, which I have collected from the swedish meterological institute. When I run it in the verification macro I keep getting the same error "Hour 7080 occurs after 7823 on line 7080 of weather file. If this is subhourly data that was interpolated using the SAM Solar Resource Interpolation macro in SAM 2020.2.29 r3 or earlier, please run the macro again to correct the interpolation" I have not used any interpolation tool, only dowloaded hourly data from the internet, and I find no error in the file. How do I fix this error? I attach the weather file here for debugging. Thanks in advance.
All the best,
Zach
All the best,
Zach
22 Feb 2023 16:30 - 27 Feb 2023 17:05 #11952
Replied by Paul Gilman on topic Importing measured data file
Hi Zach,
This problem is caused by the day after October 21: For October 22 the month value switches to the incorrect value of 11. For October 23 the month switches back to the correct value of 10.
Please check that the month numbers are correct throughout the file.
Last edit: 27 Feb 2023 17:05 by Paul Gilman.
- zskold@kth,se
24 Feb 2023 00:26 #11955
by zskold@kth,se
Thank you so much Paul. I thoroughly looked through the file before sending it but must have missed this anyway. Rellay appreciate the support.
All the best,
Zach
All the best,
Zach
