PPA for BESS + PV
- Emilio Corral
04 Nov 2022 10:19 #11655
by Emilio Corral
Replied by Emilio Corral on topic PPA for BESS + PV
Thanks for the reference.
What I understood is that the reflection losses will be calculated automatically by SAM depending on factors like tilt, type of module and reference, location, weather, etc.
How can I see a change in the reflection losses maintaining the module selected, weather, and tilt? Is there any other variable?
Best Regards,
Rafael
Best Regards,
Rafael
07 Nov 2022 15:53 #11663
Replied by Paul Gilman on topic PPA for BESS + PV
Dear Rafael,
SAM's Detailed Photovoltaic model reports the "Reflection (IAM)" loss in the results, which you can see on the Losses tab of the results page, and also as a number on the Data Tables tables tab.
- Emilio Corral
09 Nov 2022 08:22 #11670
by Emilio Corral
I hope your week is going well so far!
For the 2 MW / 2 hours BESS and PV of 1.56 MW, I'm not able to get the BESS to discharge.
It's showing 100% roundtrip efficiency and in the cash flow tables it doesn't show that it discharges, as well as in the graphs.
It only shows discharge if I use the manual discharge.
Can you please assist?
I look forward to hearing from you.
Best Regards,
Rafael
Best Regards,
Rafael
09 Nov 2022 17:18 #11673
Hi Rafael,
Please send me a copy of a .sam file showing the battery not discharging so I can help you troubleshoot.
- Emilio Corral
10 Nov 2022 11:20 #11679
by Emilio Corral
I understood from the HELP, that when using the "Automatic Dispatch" the BESS won't discharge, since the PPA rate maintains the same.
I changed it to manual, and started seeing some discharge.
I also used the PV Smoothing option, and had another option.
See attached the file for your overall review.
Rafael
Rafael
12 Nov 2022 16:07 #11684
Hi Rafael,
The battery in the "Nexans PV + BESS Manual" case does not dispatch with the Automated Dispatch option because of the cycle degradation penalty on the Battery Dispatch page, which is relatively high at $0.1/cycle-kWh. If you change the cycle degradation penalty option from "Enter penalty" to "Calculate automatically", you will see in the results that SAM calculates a maximum penalty of about $0.009/cycle-kWh. I tried the "Enter penalty" option with a value of $0.01/cycle-kWh, and the battery did dispatch.
