Weather File Downloads Issue
- Joseph Dvorak
22 May 2025 13:29 #14064
by Joseph Dvorak
Replied by Joseph Dvorak on topic Weather File Downloads Issue
Did NSRDB go down? I cannot access files to use in SAM right now. I'll try again tomorrow, but I thought I would post to see if a bigger change is in progress.
I've tried downloading by location (Lexington, KY) and lat/lon.
I get the following error in SAM logs:
NSRDB Download Thu May 22 14:30:34 2025
Requested location(s): [ -84.5003, 38.0486 ]
Location 1 of 1: "-84.5003, 38.0486"
"-84.5003, 38.0486" appears to be a valid lat/lon pair in Decimal Degrees.
Latitude / longitude for NSRDB Data Query: -84.5003,38.0486
URL for NSRDB Data Query: developer.nlr.gov/api/nsrdb/v2/solar/nsrdb-data-query.json?&api_key=&email=&wkt=POINT(38.0486%20-84.5003)
NSRDB Data Query returns no data for "-84.5003,38.0486" (outputs = []).
See sam.nlr.gov/weather for links to other data sources.
NSRDB Download Thu May 22 15:18:52 2025
Requested location(s): [ lexington, ky ]
Location 1 of 1: "lexington, ky"
Requested year(s): [ tmy ]
File 1 of 1: tmy
developer.nlr.gov/api/nsrdb/v2/solar/nsrdb-GOES-tmy-v4-0-0-download.csv?api_key=&full_name=sam_user&email=&affiliation=unknown&mailing_list=false&reason=SAM&interval=60&utc=false&leap_day=false&attributes=dni,dhi,ghi,dew_point,air_temperature,surface_pressure,wind_direction,wind_speed,surface_albedo,clearsky_dhi,clearsky_dni,clearsky_ghi&names=tmy&wkt=POINT(-84.5003%2038.0486)
Download time: 0.895 seconds.
Weather file test failed, latitude and longitude required but not specified: C:/Users/jdv223/SAM Downloaded Weather Files/lexington_ky_38.0486_-84.5003_nsrdb-GOES-tmy-v4-0-0_60_tmy.csv.
Text from file:
{"inputs":{"body":{},"params":{},"query":{"full_name":"sam_user","email":"joe.dvorak@uky.edu","affiliation":"unknown","mailing_list":"false","reason":"SAM","interval":"60","utc":"false","leap_day":"false","attributes":"dni,dhi,ghi,dew_point,air_temperature,surface_pressure,wind_direction,wind_speed,surface_albedo,clearsky_dhi,clearsky_dni,clearsky_ghi","names":"tmy","wkt":"POINT(-84.5003 38.0486)"}},"metadata":{"version":"2.0.0"},"status":400,"errors":["Data processing failure."]}
* File renamed to: C:/Users/jdv223/SAM Downloaded Weather Files/lexington_ky_38.0486_-84.5003_nsrdb-GOES-tmy-v4-0-0_60_tmy_bad.txt.
I've also tried going to the NSRDB viewer and I get an error email that no data is available much later.
I also tried using the Python SDK and nsrdbfetcher.
nsrdbfetcher = tools.FetchResourceFiles(
tech='solar',
nrel_api_key=sam_api_key,
nrel_api_email=sam_email,
resource_type='psm3-2-2',
resource_year='2021')
lon_lats = [(-84.5003, 38.0486)]
nsrdbfetcher.fetch(lon_lats)
It did not work and replied with:
{'inputs': {'body': {}, 'params': {}, 'query': {'names': '2021', 'wkt': 'POINT(-84.5003 38.0486)', 'interval': '60', 'email': 'joe.dvorak@uky.edu', 'utc': 'false'}}, 'metadata': {'version': '2.0.0'}, 'status': 400, 'errors': }
File 1 of 1: tmy
Text from file:
tech='solar',
23 May 2025 09:05 #14070
Replied by Paul Gilman on topic Weather File Downloads Issue
Hi Joseph,
The NSRDB service may have been temporarily down yesterday. Weather file downloads from SAM are working today.
Note that if you submit a latitude-longtiude pair in SAM, you should put the latitude first, so you would type "38.0486,-84.5003" for your location.
- Joseph Dvorak
01 Aug 2025 09:36 #14194
by Joseph Dvorak
I know this is late, but I wanted to say thank you. It started working again after I checked after you replied. It must have been a short interruption just over the few hours I was trying to access it. I'm glad to see that it is all still up and running.
- James Bone
08 Dec 2025 00:19 #14406
by James Bone
Replied by James Bone on topic Weather File Downloads Issue
Thanks for the update, Paul. Good to know the download issue is on SAM’s side and not a user setup problem. The wind workaround using lat/long is straightforward, and pulling solar data directly from NSRDB works fine in the meantime. Looking forward to the next SAM release so everything links properly again.
