Projected Weather Files? modelling impact of climate change on solar PV output
- Arman Bonakdarpour
17 Sep 2022 23:04 #11466
by Arman Bonakdarpour
Projected Weather Files? modelling impact of climate change on solar PV output was created by Arman Bonakdarpour
Hello SAM Team,
The weather files we normally use are based on historical records often spanning a few decades. Are there any resources which provide projected weather files for future years (ideally projected changes in irradiation and temperature because of changes in the climate - even some rough estimates would be sufficient here). Many thanks!
Best Regards,
Arman
Best Regards,
Arman
19 Sep 2022 08:56 #11467
Replied by Paul Gilman on topic Projected Weather Files? modelling impact of climate change on solar PV output
Hi Arman,
For now, the NREL National Solar Radiation Database (NSRDB) has historical data. There are plans to add forecast data, but I'm not sure when that data might be available.
We have listed some other sources of weather data on the Weather Data page. Some of these may provide forecast data: sam.nlr.gov/weather-data.html
