Sam Weather Data Format and Field Availability
- Muhtasim Haque Shadab
23 Jun 2022 11:45 #11171
by Muhtasim Haque Shadab
Sam Weather Data Format and Field Availability was created by Muhtasim Haque Shadab
From my understanding Sam requires 1 year of data and specific fields to be able to work with the data.
Problems:
1) We have 6 months of data - so should fill the rest of the time stamps with 0 ? This got the Sam to accept our file but will this be good for accuracy?
2) The irradiance that our data provides is DNI only -So should we just fill the DHI and GHI fields with 0 ? Again this made the file work but what will be the best solution for accuracy?
3) We don't have the Pressure data - Should we fill that with 0 too? Again this made the file work but what will be the best solution for accuracy?
Your help will be greatly appreciated.
Thank you
Problems:
Thank you
27 Jun 2022 09:47 #11183
Replied by Paul Gilman on topic Sam Weather Data Format and Field Availability
Hi Muhstasim Haque Shadab,
1. The value of zero may cause errors in some calculations, so a better approach might be to use weather data from a different file for the time stamps you are not using.
2. This depends on what performance model you are using. Please see the "Weather Data Elements" topic of help for a table of weather data required by the different performance models: samrepo.nlr.gov/help/weather_data_elements.html
3. If the performance model does not require pressure data, then you can omit the column from the file. See the footnotes in the table in the "Weather Data Elements" help topic for a discussion of when pressure data is required.
