Problem with Multiple Subsystems
- TimJ
19 Dec 2011 12:54 #122
by TimJ
Problem with Multiple Subsystems was created by TimJ
I use the multiple subsystems feature extensively in SAM.
In previous versions, no issues.
With the release of the new version, the multiple subsystems feature is not working correctly.
Total kwh is ok.
Aggregate financials are way out of whack. KWh / KW first year is wrong.
Someone should check to make sure the problems are fixed.
Total kwh is ok.
20 Dec 2011 17:38 #123
Replied by Paul Gilman on topic Problem with Multiple Subsystems
I confirmed your observation and am working with the development team to investigate the issue. I will follow up when I hear from them.
Thanks for pointing it out!
06 Feb 2012 12:26 #124
Multiple Subsystems does not work correctly in SAM 2011.12.2. It will be fixed for the next release, in the spring of 2012.
