How SAM handle tilt angle in System Design and tilt angle for the active surface
- Rodrigo P Maruyama
27 May 2022 16:02 #11008
by Rodrigo P Maruyama
Replied by Rodrigo P Maruyama on topic How SAM handle tilt angle in System Design and tilt angle for the active surface
Thank you for your patience.
Let's again.
Let's again.
30 May 2022 16:37 #11015
How was the file? Is it ok?
Please do let me know if you need anything else.
Rodrigo
Rodrigo
01 Jun 2022 17:47 #11035
Replied by Paul Gilman on topic How SAM handle tilt angle in System Design and tilt angle for the active surface
Hi Rodrigo,
Your attachment did not work. Please tryThis email address is being protected from spambots. You need JavaScript enabled to view it. to us.
03 Jun 2022 12:37 #11068
Hi Rodrigo,
Thank you for emailing your file.
The higher "module deviation from STC" losses are caused by the partial shading model. That model assumes the modules are crystalline Silicon modules with three bypass diodes and estimates the effect of partial shading of the modules as a DC loss in the array output. If you clear that checkbox in the Edit shading window, the modules will be treated as thin film modules that have a more linear response to partial shading of the modules, and you should see a lower module loss value in the loss diagram.
03 Jun 2022 14:45 #11069
Hi Paul, thank you to look into this.
As you said I got a better value for DC module deviation from STC losses. Now is about 5%.
My module is a P-type Mono-crystalline which makes no sense, but thanks anyway.
Rodrigo
Rodrigo
07 Jun 2022 13:51 #11091
Hi Rodrigo,
These results indicate that shading might have more of an impact on the output of a system with crystalline silicon modules than thin film modules. The partial shading model is an empirical model based on analysis of data from systems in the field that is described in the publications listed under "Partial Shading of Photovoltaic Modules" on the PV Publications page of the SAM website:
sam.nlr.gov/photovoltaic/pv-publications.html
