Turn 'off' the default Anti-Reflective Coating assumption
- Caitlin Johnson
25 Apr 2022 09:28 #10872
by Caitlin Johnson
Turn 'off' the default Anti-Reflective Coating assumption was created by Caitlin Johnson
According to the release notes, a major difference between the v2020 and v2021 versions of SAM is the default assumption that all PV modules have an anti-reflective coating. Is there a way to turn that assumption OFF in v2021 (without going back to the v2020 version) of SAM?
CaitlinĀ
CaitlinĀ
25 Apr 2022 16:41 #10875
Replied by Paul Gilman on topic Turn 'off' the default Anti-Reflective Coating assumption
Hi Caitlin,
It is not possible to "turn off" the anti-reflective coating assumption without modifying the source code and building your own custom version of SAM. For reference, here is the relevant code.
The anti-reflective coating option is set by the last parameter with value of 'true' in the calculateIrradianceThroughCoverDeSoto() function here:
github.com/NREL/ssc/blob/839cfbe86a00742455ed1104e3e6309c8e741ea2/shared/lib_cec6par.cpp#L75
The irradiance-through-cover model is here:
github.com/NREL/ssc/blob/839cfbe86a00742455ed1104e3e6309c8e741ea2/shared/lib_pv_incidence_modifier.cpp#L128
The transmittance() function is defined here:
github.com/NREL/ssc/blob/839cfbe86a00742455ed1104e3e6309c8e741ea2/shared/lib_pv_incidence_modifier.cpp#L28
