Error while importing WIND srw file in SAM
- Shubham Thakare
24 Mar 2022 01:40 #10724
by Shubham Thakare
Error while importing WIND srw file in SAM was created by Shubham Thakare
Dear SAM Team
I am trying to simulate Wind using SAM but I get the notification said "Could not check hub height compared to resource height. This may indicate a problem with your weather file". Kindly help with this issue. I have attached my srw file here.
Regards
Shubham
Regards
Shubham
28 Mar 2022 10:54 #10732
Replied by Paul Gilman on topic Error while importing WIND srw file in SAM
Hi Shubham,
The file you attached is not a text file with comma-separated data. Please see the "SRW Format for Wind" Help topic for a description of the SRW file format:
samrepo.nlr.gov/help/weather_format_srw_wind.html
- Shubham Thakare
28 Mar 2022 12:00 #10736
by Shubham Thakare
Replied by Shubham Thakare on topic Error while importing WIND srw file in SAM
this was quite helpful. I tried to navigate through a sample script to model a wind turbine as given in this Link . However I could see that PySAM-Wind output group does not give hourly wind output in kW for 8760 timestamps. Can you help me with this, How could I get the time series output from the wind turbine ?
Best
Shubham
Best
Shubham
28 Mar 2022 14:34 #10738
Hi Subham,
The output 'gen' is the time series electrical output of the wind farm in kW.
