Failed to Write the weather files.
- Md Rahan Chowdhury
02 Mar 2022 09:19 #10644
by Md Rahan Chowdhury
Failed to Write the weather files. was created by Md Rahan Chowdhury
I have set the coordinates for desired area however when I am trying to download it showing that failed to write file. Could you please help me on this regard?
One more thing is there any way to import manually the weather file (csv format)?
I have attached the screenshot of the error. Thanks in advance.
02 Mar 2022 18:10 #10647
Replied by Paul Gilman on topic Failed to Write the weather files.
I think the Unicode degree symbols in your request are causing problems. Please make the request using the latitude and longitude in Decimal Degrees instead of Degrees/Minutes/Seconds.
For example, a valid latitude/longitude pair to use for the request would be 37.367,-95.183.
