Solar Water Heating - Albedo parameter
- Chase Pheifer
01 Mar 2022 13:24 #10642
by Chase Pheifer
Solar Water Heating - Albedo parameter was created by Chase Pheifer
I was wondering if the albedo parameter has any bearing on the results of a solar water heating simulation. I have changed the value from 0 to 1, and the annual system energy did not change. Based on the manual on NREL's site, I didn't see albedo factoring into any of the equations. If this is the case, is there any purpose to the albedo input?
Chase P.
Chase P.
02 Mar 2022 18:20 #10649
Replied by Paul Gilman on topic Solar Water Heating - Albedo parameter
Hi Chase,
The albedo affects the diffuse irradiance incident on the collector. It only seems to affect the annual output at high tilt angles. In my tests the albedo affected results for tilt angles of about 60 degrees or higher.
- Chase Pheifer
02 Mar 2022 18:22 #10650
by Chase Pheifer
Replied by Chase Pheifer on topic Solar Water Heating - Albedo parameter
Paul,
I didn't think to check that. I am seeing the same results. Thanks for checking into this!
Chase P.
Chase P.
