Error message when defining turbine design characteristics
- Marc Fiebrandt
06 Jan 2022 08:49 #10476
by Marc Fiebrandt
Error message when defining turbine design characteristics was created by Marc Fiebrandt
I wanted to define a wind turbine design for a Siemens SWT-6.0-154, as I could not find it in the database.
It works fine until I try to change the "Maximum tip speed" to 88.7 m/s and the "Maximum tip speed ratio" to 6.8. Afterwards I get the following error message and the turbine power curve does not change accordingly:
equation engine: [32]: eval error in statement list\
fail: [wind_turbine_powercurve_windspeeds,wind_turbine_powercurve_powerout,wind_turbine_rated_wind_speed,wind_turbine_powercurve_err_msg,
wind_turbine_powercurve_hub_efficiency] = f( wind.turbine.radio_list_or_design,wind_turbine_powercurve_windspeeds_from_lib,wind_turbine_powercurve_powerout_from_lib,
wind_turbine_kw_rating_from_lib, wind_turbine_kw_rating_input,wind_turbine_rotor_diameter_input,wind_turbine_hub_ht,wind.turbine.elevation,wind_resource_model_choice,wind_turbine_max_cp,
wind.turbine.max_tip_speed, wind.turbine.max_tspeed_ratio,wind_turbine_cutin,wind_turbine_cut_out,wind.turbine.drive_train )
no variables calculated in a single iteration, cannot make progress!
eqn not evaluated: [wind_turbine_powercurve_windspeeds,wind_turbine_powercurve_powerout,wind_turbine_rated_wind_speed,wind_turbine_powercurve_err_msg,wind_turbine_powercurve_hub_efficiency] =
f(wind.turbine.radio_list_or_design,wind_turbine_powercurve_windspeeds_from_lib,wind_turbine_powercurve_powerout_from_lib,wind_turbine_kw_rating_from_lib,wind_turbine_kw_rating_input,
wind_turbine_rotor_diameter_input,wind_turbine_hub_ht,wind.turbine.elevation,wind_resource_model_choice,wind_turbine_max_cp,wind.turbine.max_tip_speed,wind.turbine.max_tspeed_ratio,
wind_turbine_cutin,wind_turbine_cut_out,wind.turbine.drive_train)
I could not find any restrictions for this in the SAM documentation. For a rotor diameter of 154m, a maximum rotor speed of 11rpm and a nominal wind speed of 13m/s, a "Maximum tip speed" of 88.7 m/s and a "Maximum tip speed ratio" of 6.8 should be reasonable.
If you could help me with this problem that would be great.
Thank you and best regards
Marc
Marc
07 Jan 2022 14:26 #10490
Replied by Paul Gilman on topic Error message when defining turbine design characteristics
Hi Marc,
This is a bug that we will fix for the first update to SAM 2021.12.02, which we hope to release at the end of this month (January 2022). Thank you for bringing it to our attention.
github.com/NREL/SAM/issues/877
- Marc Fiebrandt
27 Jan 2022 01:33 #10554
by Marc Fiebrandt
Replied by Marc Fiebrandt on topic Error message when defining turbine design characteristics
thank you for the quick response.
I am looking forward to the update.
Thanks and best regards,
Marc
Marc
